It says in the instructions when putting the plastic ring on to "Rotate sleeve until a slight locating position is felt before applying
pressure." I don't understand what "location position" I'm suppose to be finding. I've got it all installed and everything(I've yet to try it though), I just want to make sure I did it right.
They probably want you to make sure the sleeve is lined up with the point cams before pushing it down. My instructions say "Place the magnet sleeve over the distributor shaft and down onto the point cam. Rotate the sleeve until the sleeve and point cam line up correctly".
Frank
That's what I don't get. Are they just saying that they want the slits in the bottom of the magnet sleeve to go down over the points of the cam?
