Picked up an inexpensive plasma cutter. Read all the directions, watched many videos. They say use a #5 lens. The only thing I have at the moment is a harbor freight welder's lens. It says #5, but it's impossible to see anything through it. Can barely see the plasma arc. Probably more than a #5 lens ? I have no basis as I've never welded before btw, but will be getting a welder's helmet and start practicing welding soon - for those floors.
What eye protection are you using when cutting floors/sheet metal with a plasma cutter?
Arc Current (Amperes)Minimum Protective ShadeSuggested Shade Number (Comfort)
Less than 2044
20-4055
40-6066
60-8088
80-30089
300-400912
400-8001014
I use my auto-sensing welding helmet. You can adjust the setting once you start using it.
same here- I have an auto tinting helmet as well. I've worn dark shades a few times, but only while cutting short distances, and held the cutter such that it blocked the direct view of the light.
1969 Mach 1 351 Black Jade
Brighten up the area you are cutting and it helps alot, I had 2 powerfull LED lights aimed at my cut.
Same thing here, I tried using dark glasses, not enough tint. Auto darkening helmet kept darkening then getting light. Had trouble getting it adjusted to right darkness for all the cuts.
