right now its not doing anything. :)
sorry could not resist that
unless any one knows off hand youll need the schematic
if everything is working id say its for an option that you dont have like hood mounted turn signals or something
on my 67 390 there is a blk or blue wire coming out of the firewall along with the square 4 pin connector (see pic). What does it do?
On 67 and 68 that square 4 contact connector pair connects the underdash harness to the backup lights switch/neutral safety switch on the transmission. It should have two RED/BLU wires (NSS) and two BLK/RED wires (backup lights).
The single wire seems to be one of the BLK/RED wires from the square connector that was cut and then spliced to a non-stock wire. Does it look that way to you?
Paul
On the 4 wire connector, two of the wires go to the shifter for backup lights. Other two wires, (depending if a standard or auto) are the neutral safety wires. For a standard shift, no neutral safety so conn got a "loop wire" a jumper. For an auto trans, wires go to trans shifter switch.
