Sounds like you did it correctly, but they should be about the same height, unless the pushrods for those two valves have shortened (compressed or ground down due to lack of oil).
You might want to check by swapping a pushrod from another valve that is the "correct" height and see where the adjustment ends up.
Also, you mentioned that you did it at TDC, 180, and 270... how about the 90 setting? These two valves weren't suppose to be done there, were they?
You're just jealous because the voices only talk to me!!!
