1 - 11 of 11 Posts
Vendor
I'm going to plumb my pump to carb fuel line with Aeroquip reusable fittings and braided hose.
Can anybody tell me the adapter to get from a Carter mechanical fuel pump to 6AN? Is it 1/2x20 - 6AN?
I also need to know the thread pitch on the Edelbrock 1406 carb I have. Is it something like 5/8x20?
Thanks for all your help guys and girls!
It appears you need a #5 SAE male to #6 JIC male. The former has 1/2" 20 tpi threads and an o-ring for sealing.
This would translate to a C5315x6x5 Weatherhead fitting number. This is a steel fitting. If you need this fitting in inverted flare (SAE side), I can only find it in a 5/16" or #5 JIC male.
Likely, Aeroquip, Russell and Earls have these in aluminum but I don't have the part numbers handy.
Regarding the carb fitting, there should be a 5/8 18 SAE straight or inverted flare to #6 JIC adapter available.
In inverted flare, the Weatherhead number is C5880x6. That's 5/8 18 interted flare to #6 JIC male.
In straight thread SAE (o-ring seal), I can't find one with a 5/8 18 thread. They go from 9/16" to 3/4". That doesn't mean they don't exist in aircraft fittings.
BTW, a common carb adapter size is 7/8-20, which is used on Holleys. I don't know for sure about Carters/Edelbrocks as I've never run one *G*
Vendor
Hi Pat,
Thanks for all your help so far. I know where I can find all the fittings in the world that I need. That's half the problem! LOL! There are so many of them I have no idea what size I need for my carb...
I think it is a 5/8 that I need. I want to run an adapter out of the carb then put a 90* 6AN swivel fitting on it to shoot me out the way I need... It's the thread on the carb side of the adapter I don't know what is...
These little guys are only $3-$4 each, I may just take a stab in the dark and order a couple of different sizes...
OK, try here
I saw that 5/8" 20 Carter adapter down the page a bit. No part number though...
Haven't been able to nail down the fuel pump adapter but will post back if something shows up...
Wow, now I'm more confused than ever. I know about AN fittings (I guess) and NPT, but what's JIC? And outside of the context of electrical service, what's a weatherhead?
Sounds like me and computers, eh? *G*
Weatherhead is a hydraulic fitting manufacture and JIC is Joint Industry Council, a standards orgainization for hydraulic standards, among others. Physically, JIC fittings mimic AN fittings as to flare angle and most thread pitches and sizes. I have a number of JIC fittings on the race car where I didn't want to spend a fortune on AN fittings. The downside is that JIC fittings are steel, which is heavier.
Usually, when faced with oddball adapters, I simply chuck a piece of aluminum or brass in the lather and make one. All this part number stuff gives me a headache...*G*
Vendor
Discussion Starter #10
It was during our handshake yesterday that I downloaded your 'To Do' List! ::
I'll let you know what I find out. I'm gonna order a few fittings this week and have a go at it.
Thanks for the clarification. I'll file that away for future reference.
Yes, Virginia, there are some real tangible benefits to being a machinist. :)
1 - 11 of 11 Posts
