1 - 12 of 12 Posts
I won a special award
Depends on several factors. Fuel injected? Carbed? What are you running for induction? Naturally aspirated? Turbo? Blower? RPM level? HP level? What do you plan to do with the car? 3/8" line will be ok if it's a mild build and you're not racing it. Otherwise I would recommend 1/2".
carb, natural, wanna get 500-600hp when done with the build. wanna be able to race but will be extremely rare. thanks for the replie
I've got 3/8" on my stroked (462) FE motor. It is plenty big. Secret is a blueprinted mechanical fuel pump that will support up to 600 hp.
For that HP level I would suggest 1/2" all the way from the tank to the carb.
How do you blueprint a mechanical fuel pump? The only metallic moving parts are the arm and it's pivot point and maybe the check valves. You can't blueprint the rubber diaphragm of a mechanical pump.
Discussion Starter #8
blueprinted? Not heard of this, can you explain please and maybe give me a pic of what ur talking about, thanks
brad
Discussion Starter #11
No.... no problems with the bigger line..I am using -8 braided line..
Sweet! I'm having to run all new lines, brakes/fuel and am inpro of building that stroker but is going to takes several years to finish so i wanna throw something in in the mean time so i can drive this beast! I've never gotten to drive her, i'm gettin extremely anxious!
1 - 12 of 12 Posts
