My 66 Mustang 302 is having trouble starting up sometimes. I have Pertronix, Holley 600. I installed new plugs today. Problem is when I've been driving & stop for say 30-60 minutes it won't fire right up. I have to press the gas and wind the starter till it fires (it won't fire unless I press the gas). Then I get black smoke out the pipes. It will fire up on the 1st turn of the starter in the mornings & if it sits for an hour or longer. I noticed a small bit of gas under the carb linkage on the drivers side of the intake, but not a noticable leak. The carb is 1 1/2 years old, Pretronix is 1 year old. Everything else wires, cap, button are 1 1/2 years old also.
Any ideas? Time for a carb rebuild?
66 Coupe, 302, Auto, 3.25 gears. [color:red]Candyapple Red</font color=red> with White Pearl Stripes. Cragars.
http://web.infoave.net/~ronniek
Gosh I hope you get some educated answers to this. I've got exactly the same setup as you in my 66, and I'm seeing the same thing! I look forward to the wisdom of VMF coming through for us!
DanM
66 Coupe, check her out at http://www.66CoupeNW.stangnet.com
"Imagination is more important than knowledge. It is a miracle that curiosity survives formal education" - Albert Einstein
Sound to me like your flooding a little, maybe the floats need adjustment. The fuel probably evaporates over night that's why it's starts ok in the morning.
1966 Mustang Coupe, 302 custom roller cam, holley 650dp,http://www.289mustang.com
http://www.289mustang.com/images/vmfcar.jpg
Either that or the gas is boiling. After you shut it down for a couple of minutes listen to the carb for the boiling sound. That could cause the gas to run past the needles and make it hard to start. Maybe just need a spacer under the carb.
