1 - 10 of 10 Posts
I have been running P185-75R14 radial tires on my '66 coupe with stock wheels (14 x 6) for almost 9 years with no problems. I would like to upgrade to a larger tire. What, in your experience, is the largest tire that could be installed on these wheels safely? I'm sure I could go to a P195-75R14 but how much loarger is the question.
Thanks for your expertise!
John T.
I used to run 205/70/14s on stock rims without problems. I don't think I ever tried to go any bigger than that.
I've always tried to keep the tread width and the rim width about equal, but with a taller side wall, you will experience moer tire roll in turns
The stock V8 wheels (standard or styled) for 66 were 14x5. I've used P20570R14 tires on them for years, no problem.
I've used 225/70-14 on 14x6 styled steel wheel on a 69 back in the day. Fit fine on a 69 although a bit taller than stock.
205's are a good fit, and look right too. If you look elsewhere than tirerack.com you might be able to find some Pirelli P-4's, which I've used in the 195/70-14 size. I was extremely pleased with the outstanding performance of those tires. But I was coming from nearly 10,000 miles on a set of BFG Radial T/A tires. Which were are worst traction tires ( wet or dry) I've ever had the displeasure to experience.
So my liking the Pirelli's so much has to be tempered with the fact that I was coming from a very scary place traction wise, with numerous close calls of running out pavement. My Pirelli observations might be positively colored as a result of the timing vis a vie the Radial T/A's.
Z
PS In any case, there are choices in 14" tires other than the BFG's. I would advise that the other brands deserve a close look.
I had 195s installed a few weeks back. I wanted 205 but Discount wouldn’t install them on the stock steel wheel because their order/install software said they wouldn’t fit. Even though tons of guys have them. I could have gone to the local llantera but just went with Discount. A set of 205s look good on a stock classic Mustang.
I did 225s and they fit fine but I wish I had stuck with 215 or 205 for appearances sake, particularly for the front.
Had 2 new looking BFG come apart when they reached 5 yrs. The first one removed the left fender. the second was ready to do the right a few months later.
1 - 10 of 10 Posts
