1 - 15 of 15 Posts
Hello All,
I have a deluxe steering wheel that I am refurbishing. My current plan is to sandblast the spokes and re-chrome it. The wood-grain wheel itself has been removed and will be replaced later.
My question is can anyone recommend a product that I can use to re-chrome the spokes?
783937
783939
Hello All,
Hello All,
Hi, When people say sand blast I cringe. Eastwood sells a bluish color rust remover that's a very light acid. I would hit it with enough of that product or some other product put on a rag big enough to cover the complete wheel then saturate it with the product. then lightly sand with various grit sandpapers til you can get it to a nice finish, finish your finish up with a green pad again of varying grades until you get it down smoother and final finish with 0000 steel wool. remember to take the least amount of metal and finish on the metal as possible away. The 0000 steel wool will work on windshields it's very soft with soft pressure. Then take it in and have a reputable Chromer do his magic.
Discussion Starter · #4 ·
I cut/tore off the cracked and falling apart plastic wheel. I am hoping to replace with cherry or padauk.
That will look nice.
Plating and woodworking are way out of my skillset. Unfortunately I don't have anything I can add to help, but will be following to learn.
You can’t really rechrome it properly yourself. It requires specialized equipment. There are companies that do exceptional work, but they aren’t cheap. The process requires removing the existing chrome down to the base metal. Repairing any pits. Nickel plating the metal, then applying typically three layers of chrome. Was the original chromed, or just polished or brushed stainless?
Reactions: kenash
Too late now, but Naval jelly or Lime-A-Way toilet cleaner would have removed 95% of that corrosion.
Chrome plating can be done, of course the brushed finish is tricky. The rim can be replaced with real wood.
By the time all that's done you'll have much more in it than a replacement wheel, though, and it won't really be "original" anymore.
A bare replacement runs about $250. Plating will cost more than that.
I have the center section already rechromed. It was part of a wood wheel display. I will look for it today, and post some pictures.
Yes, it is for sale.
The 65-67 deluxe steering wheel spokes were chrome-plated steel, and the faces brushed. Then the "wood" rim was moulded on as a single piece of plastic.
Would you share with whom, or how, you are replacing the wood rim?
I have a GT, I want a deluxe woodgrain wheel with a interior color matched rim if that is possible.
Discussion Starter · #13 ·
I’ll be replacing it myself, following the same kind of process listed in the series of posts here:
DIY Wood Steering Wheel: Part 1 Introduction, Design & Prototype : How-To Library : Ford First
I am now thinking of alternating cherry and maple, possibly with ebony in the middle. The cherry will add a reddish color to match the car and the maple will add some pop!
What is the interior color you want to match?
Is rechroming really necessary in this case? I restored one with spokes in similar condition, and with some elbow grease with a scotchbrite and fine steel wool, it cleaned up really well.
Discussion Starter · #15 ·
I have some Simichrome polish coming for the three pronged horn ring, we’ll see how that does on the wheel spokes as well.
1 - 15 of 15 Posts
