This winter I plan to remove my engine and tranny from my 73 convertible so I can detail the engine bay. I bought this car off ebay as non-running with no history on the motor. I got it running fine without too much trouble and have put several thousand miles on it. I changed the camshaft when I got it because the original one was wiped. I never pulled it apart at that time to clean anything. My question is should I re-ring it and install new bearings now or just clean it up and stuff it back in? I am not completely clueless around engines but I have never delved quite so deeply before. Any help or hints on the re-bearing/re-ring procedure or any thoughts or advice in general is appreciated.
Tom, I'd do just that, just in case you decide to do any mods in the future.
I had a mint running 71 351C-2V motor that never used a drop of oil and had great compression. So, thinking I was so slick, I just slapped on a set of 70 4V heads and an aftermarket cam. That damn motor had so much blow-by when I was done I had to run 20W50 or it would push oil out the dipstick. So, out it came, a quick pass with the Flex-Hone, a new set of rings and a fresh crank/bearings and it ran perfect.
A complete re-ring and bearing job will set you back only a couple hundred bucks. If the crank is even remotely questionable, get it turned. I would also inspect the heads while they are off. If you need any help, just drop me a PT.
Thanks Hemi.
I think I'm going to give it a try. Will the bearing shells be marked if they are undersize or is the only way to tell to mic the crank?
Get this book:
http://www.motorbooks.com/Store/UserDirs/motorbooks.com/coverimages/101934.jpg
Discussion Starter · #5 ·
Thanks. That was one of last years Christmas presents. It is a great resource.
This year my wife is getting me a torque converter. She just doesn't know it yet! :p
My wife just told me the Mastercard bill arrived today and mentioned something about sitting down before I read it. "Oh, has someone been using that card?" I asked. "A little bird maybe?" Then she reminded me that this is not a good week to be a little bird, and it's even more so for really big birds. I haven't looked yet, but I know it's close to $2000 (yeah, three zeros), which is kind of hard to schmooze away.
TommyK said:
Thanks Hemi.
Yes, the bearing shells will be marked with the undersize, the part number will look like MS1010PXX. The XX will be the undersize amount. If you see a Ford logo, you can pretty much count on them being standard.
