Hi Guys,
Been slaving over my 66 i6 Coupe. While trying to replace the fuel line, I fractured the soft line that connects the hard brake line to the rear axle vent/brake distribution block. I figured I could just unscrew the leaking soft line from the block. To my surprise, it looks like the soft line is acutally part of the block. No threads or hex to get a wrench on. It is part of the block which seems sort of dumb to me frankly since the other end is threaded to the hard line.
So two questions for you guys:
-Where can I get a block with the soft line included? Did searches but can't find this part for some reason.
-Having a hell of a time getting the hard line unscrewed from the threaded end of the soft line. Also, the two side lines from the block. Tried PB Blaster and tapping method. Still won't unscrew. Any advice?
Having to remove and replace the entire block for a leaking soft line just seems kind of ridiculous, but such as life.
Any help/advice is truly appreciated.
Thanks.
Thanks.
