i replaced my 8" with a 9" inknow i need the line thatruns along the housing. But the rubber line that goes from the t that is welded to the rear to the line that runns the tunnel needs to be relaced. where can i get this part and what the hell is it called. Thank in advance
Sounds like you need a rear brake hose. It should not be welded to the rear, it is attached to the rear with the vent tube that is screwed into the housing.
