Hello,
I've used the search function, consulted the manual and tried local parts stores - no luck.
I have a 1970 Mustang H code with the 351C, 9 in. rear end and power front disc/rear drums. I measured the shoes and they are 2" wide and the drums are 10 X 2.
I can't seem to find all the correct part numbers (at one place) for rear drums, brake shoes and wheel cylinders. It looks like I need the 29/32 wheel cylinders, but would like confirmation in that.
Thanks for any help with identifying the correct part #'s.
Well---First off, If you have 2" shoes, and 2" Drums (Actual braking surface) you have a problem.
The 2" (shoes) rear drums have a braking surface of 2 7/16"
The 1 3/4" (Shoes) rear drums have a 2" braking surface.
Do not put 2" shoes in a 1 3/4" drum--Unless you have a death wish.
Which have you got? Cylinder/shoes/drums have different numbers.
Hardware is all same, can't go wrong there.
We carry it all.
Thanks Dan.
The shoes are exactly 2". The drums measure 2 1/4" braking surface. I'm guessing someone mixed and matched parts over time.
Good, Exactly as it should be.
Shoes 152
Drums Generic 8736----Raybestos 2637R
Cylinders---Left rear WC 36019
Right rear WC 36020
Hardware 7045
Adjusters 2514/2515
