I am finishing up the brakes for my car, and have the kit shown below. When I took the tired off from getting the car back from the body shop, the rear rotor basically slid right off after the wheel. I always thought that the rear rotor was bolted on in some way different from just the wheel holding it on, but I don't see any other way. Is the rear rotor simply heald in place by the rear wheels? Is that secure enough? Thanks.
http://www.stainlesssteelbrakes.com...el=Ford+8"+&+9"+Rear+Ends&year=
Yep and yep. The caliper should also prevent the rotor from falling off when you remove the wheel...
Dave
Ok, so I assembled the rears, but didn't bolt down tight. On one side, where the caliper bracket bolts to the axle, there is a head of a bolt on the rotor side. When I put the rotor on, it hit one of the heads of the bolts. I used one of the thin spacers (approx. 1/8") to move it just past the head and clear it. Is there any problem with doing this? It is such a small distance I figure it wouldn't matter, but I thought i would ask. The other side clears just fine.
