Does rear diff tag go under copper washer or on top?
also
Does rear diff tag go on a certain bolt on housing? I removed mine from a bolt on the opposite side of diff to fill plug, but i've seen a picture of a tag bolted right next to the fill plug... or does it matter.
thanks, david
I put all the washers in 1st since they help seal, then the tag and nuts. Mine was, and is, bolted to about the 3 o'clock position and pointed down.
I'd think you'd want the copper washer to be crushed again pumpkin as to seal it. As said, I'd do washer, tag, nut
