1 - 1 of 1 Posts
Vendor
Are you ready to add rear disc brakes to your Ford axle without breaking the bank?
The GPS Automotive rear disc brake kits include
  • 63.5mm Zinc Plated Single Piston Calipers with Built-In Parking Brake
  • Precision Machined Caliper Mounting Brackets with Multi-Position Mounting Capabilities
  • All Mounting Brackets are Zinc Plated for a Long Lasting Finish
  • 11.25" Vented Rotors with Ford 5 x 4-1/2" and GM 5 x 4-3/4" Bolt Pattern
  • DOT Rubber flex lines with 3/8-24 SAE female inlet
  • Brake line mounting tabs, spacers & mounting hardware
  • Complete installation instructions walking you thru every step of the installation with pictures.
Check out the links below to choose the correct kit for your axle.
8" & 9" Small Bearing Rear Disc Brake Kit
9" Large Bearing Rear Disc Brake Kit
9" Large Bearing "New Style" Axle Rear Disc Brake Kit
1 - 1 of 1 Posts
