what causes rear end howling in my 66 mustang, 289- c4 it only does it at slow speeds????it has fluid
Could be a couple of things:
1.excessive backlash and/or wear in the gears caused by 30+ years of service.
2.Worn or pitted carrier and/or pinon bearings (same cause as above)
3. Worn axle bearings.
I hope this helps you out. Scott
Every day is a holiday if you love your job.
Current projects: 65 Fastback, 68 Coupe Oval Track Racer, 64 Galaxie 500 XL, 54 F-100 Pickup
Clicks could be dry suspension bushings or shock mounts too...
If the clicks are speed dependent and constant, could be loose lug nuts...
Wheel bearings going bad usually start with a quiet howl, which is speed-dependent and gets louder as the bearings wear out.
A loose u-joint can click as well at low speeds...
Wow, that narrows it down...*G*
Pat
