Anyone have any info about final drive gear ratios in 65-66 mustangs, as in what different ratios were offered, how many were produced, what ones came with what code (A, K, etc.) cars? Also, I heard they generally put higher gears in standard transmission cars and lower in automatics. Is that true? Thanks for any info you may have!
The rear end was an option, you could get whatever you wanted. Normally, if you didn't order it specifically, you got something that was typical for a particular motor (i.e., a 6 cylinder car didn't come with a 3.50:1). You can find a list of options at the main website here: www.vintage-mustang.com/topics/decode/decode.html.
The Mustang recognition guide shows the following available:
1965
170 - 3.50 ratio only
200 - 3.20 ratio for manual trans, 2.83 ratio auto trans 260 - 3.00 ratio only
289 2V - 2.80 manual trans, 3.00 auto trans
289 4V - 3.00 ratio for both manual and auto trans cars
289 HIPO - 3.50 standard ratio, optional 3.89 & 4.11
1966
200 - 3.20 manual trans, 2.83 auto trans with 3.20 optional for auto trans
289 2V - 2.80 for both manual and auto trans
289 4V - 3.00 for both manual and auto trans
289 HIPO - 3.50 standard ratio, 3.89 optional ratio
