When I got my 65 vert the po had started to install the driver side rear 1/4 panel . I have began to finish with spot welds. How did any one spot weld the 1/4 panel lip at the door jam? or how did you secure it ? po used a pop rivit to hold in place I believe. Any info or Ideas would help? Thank you!
I just finished replacing my quarters yesterday. I drilled 1/4" holes in the lip every 6" or so and "plug welded" those holes to the jamb.
Damn there that girl again.
yeap that the way i did mine
drill holes every 6 inches and weld it in make sure the metal behind the panel is ground down
chris
Thank you guys sounds like a plan
