This may be addressed elsewhere, if so I apologize. I plan on replacing my rear seat divider when I take the seats out of Diane for recovering. The new ones from CJ and Summit are cardboard and look cheap. I'm wondering if I could use 22 gauge galvanized, using the cardboard for a template and bolt or tack weld it in. A little bit of fire foam caulk and some black paint plus some faux Dynamat as well. Any thoughts on this?
Wow! Thanks for the info! You saved me time, frustration, and money!
I think I got mine from Mac auto parts...and yes its 22 gauge. I have not yet installed it though since I plan on welding it in instead of bolting it and plan to run some x bracing behind it(22 gauge is kinda flimsy and will likely sound like a drum without some type of reinforcement, whether its bead rolling or bracing)
I got the one from NPD I believe and screwed it in place. Painted it black and I then added some strips of dynamat to rid myself to the tin can sound. Works well! Actually really helps reduce road noise and exhaust drone in the cabin I find.
That is the difference...I refuse to EVER use dynamat or equivalent products on a car of mine again. I learned that lesson the hard way...its a moisture trap that makes working on the interior metal of your car miserable. I also wont buy a car with the stuff installed, it makes even a quick glance under the carpet at the condition of the floorpans impossible. To me a slightly quieter car isn't worth the weight, the PITA if you work on your car, or anything else.
