i bought a new 3/4 rear sway for my stang today.. and its a straight bar, not the curved kind to clear the pumpkin... so im not sure exactly how to install it, it didnt come with instructions...so if anyone maybe had some pics of how to put in the str8 style rear sway , or any tips, id appreciate it a bunch.. thanks
I haven't installed mine, but it sounds the same as yours.
The ends are bolted to the leaf spring, the straight part to the rear subframe above the pumpkin.
You mount the ends onto the leaf spring, then swing it up to find the right spot to drill holes in the rear SF, using the brackets as templates.
Drill the two holes per side, slip the square U-joint through, and bolt it up.
what about the long bolt end links that came in the kit with all of those round bushings ?
Not the best of pics but see if this helps any........ http://a4.cpimg.com/image/10/84/22875664-709c-02000180-.jpg
thats perfect , thanks alot !!
