Sorry, I don't know what you might have to pay. I suppose it would vary greatly with what all was wrong with your engine. Seals making noises? I guess I've heard that at the zoo. Sorta an "arf arf" thing.
Seals making noises in an engine? I don't know. Maybe someone else has insight...but I guess what I wanted to post was that you'll need to have your heads reworked no matter what else you do. Taking some high milage heads, which may or may not have problems with valves, seals, springs, rockers, etc....right over to a new short block...probably won't give you the results you're looking for. In fact, you might find you have exactly the same noises as before.
Exhaust manifold seal? Now that'd do it! Ask your mechanic again and post back.
Good Luck!
Phil
Good Luck!
Phil
