1 - 2 of 2 Posts
-REBUILT T-5 5 SPEED TRANSMISSIONS-
http://www.brooksbalogh.com/astropics/DSCN1166.jpg
1986-95 Ford Mustang 5.0L 8 Cyl. T-5 $595.00
"World Class" High Alloy 5 Speed with core exchange
1986-95 Ford Mustang 5.0L 8 Cyl. T-5 $799.00
"World Class" Super Alloy 5 Speed with core exchange
1996-Up Ford Mustang 3.8L 6 Cyl. T-5 $595.00
"World Class" 5 Speed with core exchange
-NEW TREMEC 5 SPEED TRANSMISSIONS-
http://www.brooksbalogh.com/astropics/DSCN1143.jpg
Tremec TKO-500 5 Speed Transmission $1,553.00
Part#TCET4615
Tremec TKO-500 5 Speed Transmission $1,575.00
Part#TCET5201
Tremec TKO-600 5 Speed Transmission $1,585.00
Part#TCET5008
Tremec TKO-500 & TKO-600 5.0L Bellhousing $ 189.00
Tremec TKO-500 & TKO-600 4.6L Bellhousing $ 289.00
31 Spl. Slip Yoke $ 70.00
-CUSTOM-BUILT G-FORCE T-5 TRANSMISSIONS-
http://www.brooksbalogh.com/astropics/DSCN1134.jpg
Astro Prepped/G-Force T-5 with Helical Cut/Synchronized $1,595.00
2.95 1st Ratio Gear Kit, .59% Overdrive, Stock 28 Spl.
Mainshaft, All Steel Bearing Retainer, 7T Speedometer
Drive Gear, Cluster Support Plate, and Complete
Overhaul Kit with Synchronizer Rings. These transmissions
are priced to sell, and can hold up to 600HP!
Astro Prepped/G-Force T-5 with Straight Cut/Dog-Ring $CALL
Transmission with 2.95 or 3.22 Ratio Gear Kit. Transmission
comes complete with G-Force Gear Kit, Bronze 1/2 & 3/4
Shift Forks, 1018 Alloy Shift Lugs, Complete Bearing and Seal
Kit, 7T Speedometer Gear, .59% Overdrive (5th may be
removed/deleted @ no charge), All Steel Bearing Retainer, and
Cluster Support Plate. These transmissions are priced to
sell, and can hold up to 650HP!
5 SPEED TRANSMISSION PARTS
T-5 "All-Steel" Throw-Out Bearing Retainer $29.00
-Fits 1986-93 Ford Mustang 5.0L with T-5 Transmission.
Comes with Front Input Shaft Seal.
T-5 "High-Alloy" Gear Kit $289.00
-Includes Cluster, Input, 2nd, and 3rd Gear.
http://www.brooksbalogh.com/astropics/DSCN1230.jpg
T-5 "Super-Alloy" Gear Kit $399.00
-Includes 2.95 Cluster, Input, 1st, 2nd, and 3rd Gear.
T-5 "Master" Synchronizer/Blocking Ring Kit $ 69.00
-Includes all 9 Synchro/Blocking Rings in T-5 Transmission.
T-5 "Master" Bearing and Synchronizer Ring Kit $149.00
-Includes all M/S, C/S, and Needle Bearings. Kit also includes Seals, Small Parts Kit, Synchronizer Ring Kit, Tailshaft Bushing, Shift Fork Inserts, Synchronizer Key and Spring Kits, Shims, Shifter Cup for Offset Lever, and More.
G-Force T-5 Helical Cut/Synchronized Gear Kit $1,095.00
-Includes Cluster, 26 Spl. Input Shaft, 2.95 Ratio 1st, 2nd, and 3rd Gear.
G-Force T-5 Straight Cut/Dog-Ring Gear Kit $1,695.00
-Includes Cluster, 26 Spl. Input Shaft, 2.95 or 3.22 Ratio 1st, 2nd, and 3rd Gear. Kit also includes Bronze 1/2 & 3/4 Shift Forks, 1018 Alloy Shift Lugs, and 1/2 & 3/4 Sliders and Hubs.
MANY OTHER PARTS AVAILABLE FOR 4, 5, AND 6 SPEED TRANSMISSIONS. WE HAVE A WIDE VARIETY OF NEW AND USED PARTS. PLEASE EMAIL US WITH ANY QUESTIONS YOU MAY HAVE, OR FEEL FREE TO CONTACT US TOLL FREE.
Thanks,
Tony
[email protected]
(866) 253-0019 Natl.
http://brooksbalogh.com/astropics/corral.jpg
1 - 2 of 2 Posts
