1 - 11 of 11 Posts
I have distributors which will be recurved to you engine combination. DS11 & HEI's
billythedistributorman&live.com Thanks Bill
What do you have for an otherwise stock 65 with 289 & 4 speed?
Might save us both some time if you were to list a few examples of pricing.
HEI or DSII. Does that mean no points dizzy's?
Discussion Starter #4 (Edited)
For 6 cylinder engines. 200-250 engines
Hei's recurved for you combo. $225.00 + $25.00 shipping. Have adjustable vacuum advance.
DS11's are recurved for your combination. $195.00 + $18.00 shipping to the lower 48. Have hardened gear & adjustable vacuum advance.
All curves are plotted on a Sun Distributor Tester.
[email protected]
Discussion Starter #5 (Edited)
Hei's recurved for you combo. $225.00 + to your zip code for shipping.
[email protected]
Don't at all mean to highjack but looks like you have a Sun 404? I'm still using a Sun 500 I've had since late 70's. Nice to see another one still in service.
I converted mine to all solid state several years ago.
amazing that 2 small diodes replaced a 6" vacuum tube.
Technology. AAA+++
Discussion Starter #8 (Edited)
Shipping Cost Updates
Hei's recurved for you combo. $225.00 + shipping to your zip code.
[email protected]
Shipping cost update.
Can you explain the difference Pros/Cons between the DS 11 and the HEI options.
Discussion Starter #10
Good question.
I can pinpoint the curve more precise on the DS11. However limiting the total centrifugal requires welding or brazing.
I stay away from the Ford Duraspark Module, cause it does not run a full 12V.
I like the MSD-6al as a box cause MSD makes a harness MSD-8869 where you can direct connect the two. All you need is a coil with very low primary resistance. Be it a MSD Blaster 2 or 3. The best is the Ford TFI coil.
You can also use a GM module as a trigger, but it requires a lot of wiring.
The DUI for the small six is a piece of junk. It has a 2 piece housing which starves the shaft of necessary lubrication. Some came with a rotor which binds the centrifugal advance weights. Wiped distributor gears.
The HEI which i market is recurved for your application has none of these problems.
All you need is a relay to supply a strong 12 Volts to a one wire hookup. Also has a Tach connector wire.
Very popular since its a one wire deal.
I do believe the MSD with the multiple spark below 3000 rpms is a little smoother at lower speeds.
Its a toss up, i just installed a HEI in my 67 Mustang 6 & i am very pleased.
1 - 11 of 11 Posts
