I understand use of a relay to directly power a device from the battery. Example: powering a device that has a 14 gauge power wire. The relay is wired to the battery using a 6-8 gauge wire, then a power wire (6-8 gauge) is run to the device. Since the power wire attached to the device is a thinner gauge (in this case 14 gauge), does connecting the thicker gauge wire to the thinner wire from the device have any concerns?
My specific issue is when my AC evaporator fan kicks on the voltage drops from 14.3 to 13.6-13.7. Then when the compressor kicks in the combined voltage drop results in a reading of 13.1-13.2. My thought is to connect the evaporator fan directly to the battery using a relay to avoid that stress on the electrical system.
Thank you
Allen
Thank you
Allen
