1 - 12 of 12 Posts
Car is up on jack stands. Took off coil spring with compression tool. Put it on the floor to back the tool off the spring. As I was backing off on the tension, I felt like I did not have enough threads left to fully release the pressure. So, I put it back on the car and released it. Did I grab too much spring length? Or did I just not have enough thread in to start with?
What kind of compression tool are you using? I used the OTC 7045B without issues. Do you have some pictures?
If you clamp the compressor on the next shortest ring of the spring, you should have enough to completely decompress.
Banned
I've used those style of spring compressors several times that you rent from the auto parts store. You have to get a 2"-3" or so section of pipe make it work properly.
If you're not planning on reusing the springs you can whack them in the middle with an acetylene torch or Sawzall...
Discussion Starter · #11 ·
Springs finally out. Expanded the double jaw compressor to 15 1/4” so I knew it would have enough to release tension. The springs were actually 15 1/2” standing free. Driver side top shock mount bolt was spinning so I cut a screwdriver slot in it and got the nut off.
Thanks to all of the replies, helped me out greatly. ?
Discussion Starter · #12 ·
Rented the OTC spring compressor from auto zone. Had time to set it up before work. I’ll compress it tomorrow.
I did not like this compressor, just didn’t like it’s method.... and went with my first one.
1 - 12 of 12 Posts
