Sandy: I have had mine out and in a couple of times (it gets faster with practice). First, remove the shock out through the top of the shock tower (remove mounting nuts at bottom area of springs, and bolts at top of shock tower) The type of compressor that I use looks like a couple of bent fingers on the top and the same on the bottom (but facing each other) with a long screw connecting them. With the wheel off, support the weight of the car under the lower control arm, hook the "fingers" over the coils, near the top and bottom, on each side (opposite each other, one front and one at rear) and start screwing the "fingers" together. It will take a while so take your time, and remember that there is a lot of stored energy in those compressed springs and will do a lot of damage if they pop out of the compressor. When they are compressed enough, you can lift the spring up, tilt the bottom towards you, and out she comes. If I forgot anything, please read the other posters and follow their suggestions. Good luck and be SAFE. Mark
http://www.classic-mustang.net/ReadersRides/MarkMustangs.jpg
