OK I searched but Couldn't find what I was looking for.
I want to Know how to remove the Trunk lock Cylinder from its chrome housing.
I'm not sure if 65 is different than 67, but on the 67 there is a clip holding the cylinder inside of the trunk. You pull the clip off with some pliers and it's free.
There should be a little button on the 65 and 66's that you have to push to release the cylinder. My button was frozen and had to be "coaxed" out and I ruined the lock cylinder. You may also have to rotate the key in the cylinder but not 100% sure on that one
Discussion Starter · #4 ·
I see that button and It wouldn't budge with normal human force, and I tried a few light taps with a punch to no avail. I tried both of these in many key positions. At that point I figured I was doing something wrong and decided to ask! The housing is crap I want to replace it but the cylinder is still good.
As mentioned above, insert the key and rotate it about 45* then use a small drift to push in the pin at the rear top of the chrome housing. The lock cylinder should slide right out.
My pin acted the same way even with the key being rotated. Thats when the "coaxing" came into play..."coaxing" =small punch and hammer and purchasing new parts. HTH
I am so glad that I am not the only one who believes that:
"If it won't come out, you are using the wrong size hammer."
I have a 5lb sledge that is a good motivator for any stubborn part. I usually just have to set on the floor next to me, and then the part behaves.
