I pulled my 8" rear end out to change the gearing and I can seem to get the axles out. I removed the 4 nuts in the drum and spend 30min on it with a slide hammer. :shrug::shrug:
I guess I should get a bigger slide hammer. Any tips and tricks would help, before I pull the sledge out. Thinking of bolting an old drum on backwards and beating the hell out of it. Car is a 68 and this is the first time its been pulled apart.
Thanks Jay
My guess is the bearing is holding it up. Seeing as this is a good time for new bearings & seals, maybe a little heat will help? I've never had as tough a time as you are, but I may just be lucky.
Il give the drum a try but my slide hammer is heavier so I dont see it working. I will try some heat to. Im going to fasten a heavier slide hammer tomorrow.
Thanks for the imput
Got them out had to turn the drum backwards, snug up the lugs and smoke it with a sledge until it came loose.
It sounds dumb but sometimes you can go Hillbilly on it....take about 3ft of rope, tie one end around the axle, the other end tie to a cement block...swing the block to pull the axle......don't laugh it works, just don't let your buddies see you..kinda like riding a moped... :)
Tom
