Thanks, Laurie_S for the tip to use gasoline and a plastic scraper. I cleaned the underside of the damaged 68 fender, removing all the undercoating. A gas-soaked rag to transfer the gas and the scraper removed most of it; cleaned up with the gassed rag. Final cleanup with Purple stuff. Took about 30 minutes.
I did this outside the garage in the open; had no electrical components nearby; smokes inside the garage. Poured a small amount of gas into a metal pan for oil changes, and used safety glasses and a respirator.
I should have used latex gloves...anyone know how to clean grease from under the fingernails?
http://clubs.hemmings.com/baymustang/platesmall.jpgLet me check your shorts! My multimeter is just a-waiting! Formerly known as Midlife in the old VMF.
King of the Old Farts *struts*
