1 - 10 of 10 Posts
Any tips? Heat gun? Scrape? Paint thinner?
Product Sleeve Grey Collar Beige
1965 Mustang Coupe plane Jane 6 cyl manual
I used a razor blade where I could. Cleaned up with 3M adhesive remover. Not a fun job.
I used the raw material felts (i.e. not pre-cut or pre-glued). Cut one piece to form an L shape for floor and one side, then a thinner strip for the other vertical section.
I also used a blade for the sides and had a sharp chisel that fit nicely in the bottom. I bought the replacement strips from NPD but I cut them to size to install in 3 pieces. 2 for the sides and then the bottom piece. Worked nicely for me. The replacements are very sticky, a one shot deal that's why I decided to do it in sections.
I think I’d use a wire wheel on a grinder……
1966 mustang convertible sprint 200, manual steering and brakes
Maybe some solvent then heat to soften up the glue ? My preferred method is a wire wheel - bench mounted if possible, die grinder if not.
As above. I just did mine a couple of months ago. Most of the felt can be peeled out. What was left I removed with a small old chisel that fit right in the bottom. Just scrape as much out as you can. I used the replacement felts with the adhesive already on. Cut into three strips after measuring and installed the floor first and the sides second. Pretty easy.
Reactions: Caper50
The adhesive is tres sticky, like I said a 1 shot deal.
Interesting, I read that but I found the stuff I got from NPD wasn't as bad as people said. I was able to adjust it a bit. Maybe they changed the adhesive.
Russ, would be a good idea too to grab a can or 2 of cavity wax. I spray it in crevices and the back side of panels that will be covered up. It is great to seal against moisture down the line. It will run a bit when 1st sprayed but sets up rather quickly and any that drips where you don't want it, easily wipes up. They usually come with a spray wand to for hard to reach spots like between the wheel house and quarter panel.
1 - 10 of 10 Posts
