removing windshield goo
863 5
I'm getting to the point that I want to start working on my roof areas and seems smart for me to get the windshield adhesive cleaned off before I start sanding. Would a surface prep wax and oil remover like PrepSol liquify this stuff? Or should I use lacquer thinner? These were the two options I've considered. If possible I'd also like it to work on rubberized undercoating that the PO sprayed in my trunk areas. What solvent works the best?
66 C-code convertible
66 C-code coupe
65 GTO hardtop
76 Nova hatchback
FIRE! hehehehe - Solvents are the best. But nothing can beat free elbowgrease and a puttyknife! Simple Green Might work I use it exclusively on the inner fenders of my car, and it cuts through lots given enough time.
I used CRC dialectric cleaner and it worked pretty well, especialy on the trim. Good luck!
Black primer 66 coupe, bench seat, 68 302-2V, C-4, 3.55 TSD
879 posts as "66 bench-coupe" on old VMF
robert94928 on Yahoo Messenger
I posted a similar question last week and if you have this **** on your window moulding midlife suggested using a penny with lacquer or paint thinner. he said the copper penny is softer than the stainless moulding and wont scratch it. I havent done it yet but it sounds very feasible. good luck.
~Chris
San Antonio, Tx
66 coupe 289
70 fastback done by may/graduation...hopefully
