My tail lights only work after I smash the the pedal a couple of times. I thought to first replace the switch on the pedal. The conector came off easy enough. The question is taking the unit off the pedal.
There seems to be a strange pin holding the switch to the pedal. Is there a special trick to replacing the unit? Unfortunately my field of view is blocked by the stearing column.
Push the pin off and you will be able to get the switch out.
One sode goes over the stud and the other side hooks on.
I am guessing (on year) as you have not filled in your profile to tell us what year you have etc.
Gone but never forgetten
Yes, there's a trick. Hire a 1 foot tall midget, or a Japanese contortionist. The switch on a '65/'66 is a pain to even see, let alone get to, at least for us old farts. I just replaced the switch in my son's '65 last weekend. The switch was replaced in 10 minutes ... but it took 2 hours to be able to stand up straight again.
Discussion Starter · #4 ·
Sorry John:
I have included that info in the bio.
The vehicle is a 1966 covertable without power brakes. Trying to remember the pin - do I turn the pin from six o'clock to nine o'clock and then pull it out?
Is the system under and tension to create flying objects?
No, you just push on it where it is. You have to reach up there in an awkard angle.
I usually sit on the ground and reach up with my left hand.
Good luck!
Well, there are two things in this world that are hard to do or impossible. This is one and the other is putting a door back together after you stripped it to a bare can.
Can't help you my hands are too big. Seriously, a long set of needle nose pliers can do wonders.
