· Registered
I am replacing a cam in my new rebuilt 86-91 302 HO motor with a B-303. I put the marks pointing toward each other and took the bolt out of cam sprocket but cant get the sprocket off. Is it ok to pry it off? Thanks,Tony
· Registered
It's like a motorcycle sprocket; it has to be pulled STRAIGHT OFF......if it's really resistant to that, I MIGHT gently try a gear puller and as a last resort, 2 larger screwdrivers VERY GENTLY.
Just the way I'd do it.
· Registered
Cool......good luck with the new cam!!
And if I might make one final suggestion, definitely use the cam break-in lube, AND INSTRUCTIONS....and if it didn't come with break-in lube and instructions, I'd get them from the cam manufacturer. The first 20 minutes are CRITICAL to prevent cam/lifter damage.
