Other than taking the inside door panel/door handle/window handle off do I need to take anything else apart? I assume I can get to the mirror screws/nuts for the mirror once the inside door panel is out.
That should be it..
You'll need to disconnect the cables to the back of the lever on the door panel before you can remove the panel completely. But you probably already knew this.
