I am replacing my old oil pan - the plug leaked a bit and the pan itself had seen better days.
Anyway, couple of questions:
(1) While I've got the oil pan off, is there anything I should inspect on the bottom of the engine?
(2) There is some "grit" on the bottom of the old oil pan (feels like grit when you rub it between your fingers) - about the size of grains of sand (about 50 grains total). Some of these grains are metal shavings. The engine runs fine. It was rebuilt by the previous owner ~65K miles ago. The oil plug is not magnetic so it does not attract any metal. I've never seen any metal when I've changed the oil previously, so I assume that this is a total accumulation since the rebuild. Just wondering if I should be concerned by this. Anything else I should check?
