Wanting to hook up my trans. Noticed some small cracks in flywheel. How much can you safely turn one? It measure's right now at 15/16' wide. Is there some spec's. some where to go by? It is an 11'' part # C5AE 6390-E Any help? Also has anyone ever used the Zoom
Pefection clutch kits and are they decent? Thanks in advance. Jim
If it has heat cracks, it has hard spots. Don't bother; just get a new one, preferably steel if you are doing a performance build.
No idea on the clutch. We always used 3 and 6 pucks; not exactly passenger car stuff :D
Pat
Hello Pat, your right. I was thinking that also. I have another one but wanted to use the one that came off the motor. It was balanced real good, but the other one i have has the same casting # so It should be the same balance. Thanks Jim and extended project still in progress.
Personally I prefer diaphragm clutches. I use a Centerforce myself. Much less pedal effort, even with the big assist spring (under the dash) removed.
I have never had a problem with the clutch pedal sticking to the floor even at 6300 rpm.
The pedal sticking to the floor happens when the big assist spring is installed...
I use an 11" setup made by Qualitee. It has a diaphram presure plate and I love it. I was a little suspect since the engine is warmed up but no problems since I put it in back 2000; it has never slipped as far as I can tell. I had trouble with Centerforce so out it came. Have a good automotive machine shop look at the flywheel. They can be ground a couple of times prior to discarding. The counter weight is onthe back of the flywheel, so grinding it won't effect offset weight.
