Sometimes when I'm driving, the reverse lockout cable on the toploader doesn't snap taught and ratttles a bit. This also makes shifts to second a bit tricky. If I shift in and out of reverse a couple of times, it will then snap taught like it should. This is beginning to happen more and more frequently. Is there a procedure to fix this easily?
Thanks,
Troy
Time to check and likely replace the cable
