I got split in my RF brake hose over the W/E.
The brakes were 100% overhuled in 1993 (about 2000 miles.)
I also replaced the fluid every few years.
im thinking since I have to bleed the system anyways would it be benificial to replace the other brake line as well.
while im at it the calipers too? or leave well enough alone and just do whats broke.
If the condition is ok... I'd ust fix what's broke... otherwise before you know it it'll be a whole new system in there.
If both hoses were put on at the same time I would replace both. They are not that expensive and you have to bleed the system anyway.
Just some guy
If one brake hose split and and broke, I'd not trust the other one.
I can't think of a reason to replace a caliper that seems to function correctly.
welp just pulled both wheels and reached up under the left side and shes hard as a brick. im fixin to call NPD right now for new 2 hoses.
