Just verifying...
I have someone wanting to sell me these rims. They are 14 inch, 5-bolt, listed for 64.5-67 Mustangs. They would fit my 69 convertible, wouldn’t they? I’m not concerned with non-date matching.
Rims should bolt up no problem, but it appears to 235/75/14 tires. That’s a lot of sidewall, may have rubbing. It “should” be ok in rear if you have good leafs, but may rub. If all tires are that size, you may have issues in the front. If you want the tires And rims, I would try before you buy.
The wheels will fit fine, but as both commenters mentioned above....The Tires may rub being 235's and if your '69 has disc brakes, The Wheels may not clear the calipers... Two things to watch out for...
:eek:)
Tony K.
