That's another negatory, Good Buddy. The Aluminum heads will require a completely different valve train geometry and different rocker arms. I would suggest something like Harlan Sharp rollers. Then you will need an adjustable push rod to determine what the length should be. Search online for that procedure. It involves marking the valve tip with a sharpie, turning the engine and seeing where the rocker contacts the valve. Once you determine the correct push rod length, you will have order custom, hardened push rods. That could take a while.I was under the assumption I could use the originals until I researched a bit
Sorry, but them's the facts.
