Hi i am putting Crane golden rocker arms on my mustang but i am not sure what the book says buy make sure the camshaft lobe is all the way down? How do i do that?
thanks john
They want you to make sure the valve is all the way closed to adjust or shim them. Just take the valve cover off (you have to anyway) and turn the engine by hand untill you see them closed or all the way up.
What they want is to make sure the cam lobe is at it's lowest point. One way to ensure that is to rotate engine until valve is open all the way, then rotate engine one full revolution. That will put the lifter oposite the highest point, which is the lowest.
