1 - 10 of 10 Posts
Recently I've been wanting to add rocker molding to my '70 sportsroof, but it isn't reproduced. Since 65-70 mustangs share the same rocker panel and have the same wheelbase, would the 65-66 or 67-8 rocker molding fit? Just curious. The 67-8 looks fairly similar to the optional 70 rocker trim (I'm not talking about the Mach 1 trim panel).
Thanks,
Joseph K.
(actually Slim Jr now)
Maybe a reason for no response is you can look in most any catalog and see. '65/'66 are
same or similar. '67/'68 are same. '69 and '70 are diff from each other.
They may fit but they each type looks completely different!
Discussion Starter · #4 ·
I can't actually look in a catalogue and see for myself. You see, I asked if the moulding would fit, not if it was concours correct. Simply looking in a catalogue wouldn't answer the question, but thanks for the suggestion.
Once again, the reason I asked is because the '70 moulding isn't reproduced and it DOES sort of resemble the 67-8 moulding. Regardless, just because it didn't come from the factory that way doesn't mean it wouldn't look good, which isn't even the question I asked, and is another matter entirely. Plenty of Mustangs have parts that are from other year model mustangs--engines, trannies, seats, spoilers, paint color, &c. &c.
Again, my question was simply if anyone knew if the moulding was interchangeable with regards to fit, and I guess this has mostly to do with the angle of the sheetmetal, and other such factors.
Thanks,
Joseph Knight
I just pulled mine off my car the other day and had plans of ebay but if your interested PM me. They are the ones on my pic below.
Dave
Discussion Starter · #7 ·
thanks, that's great!! I didn't know anybody was reproducing them...hadn't seen 'em in any of the major catalogues. I'll keep that in mind.
Thanks again,
Joseph Knight
I know this will only add to your questions. But Im sure there's an extra inch on the 69-70, and the 71-73 although the rocker panel shape is different. Not definitive, I know, but wait til you know for sure before purchasing anything.
Any local shows coming up? I'm sure some guys will let you measure as long as you use a cloth, sewing yardstick.
Mark
Notice if you read my response. Said they may fit
but look a lot different!
1 - 10 of 10 Posts
