I've nearly finished porting the heads for my new engine('66 289) and have to deciede weather to fit press in or screw in rocker studs.
I've been told that taping the treads for screw in's is a tricky job and you will stuff the head if you get it wrong .(Having spent somewhere between 40 to 50 hours with a die grinder I'm not teribly keen to start again.)And then i'm told press in studs will pull out if you fit a bigish cam.
The Cam I intend to run is a Speed pro CS-1020R (.474/.498lift 214/224*duration.)Any opinions should I go Press in or screw in????
Has anyone fitted screw in studs if so did you encounter any dificulties or can you offer any tips or advice?
