Any good way to roll fenders on a bare shell? My 65 FB restoration is just a shell and would like to roll fenders prior to paint and before suspension and axle goes in. Any ideas?
If you have the front fenders off you can use sand bags on the ground place the fenders on it and hammer the lip . On the rear I used a hammer and dolly to roll the lips good luck.
Here is what I did with my 70 FB, I don't know if your 65 is just the same, I suspect it is. On the front fenders, I trimmed the width of the underside lip by about 1/2. You don't have to do the entire length of the fender lip, only about from the 10 to 2 position. Then you can work then over with a dolly and hammer or on a bag as mentioned. This is how the factory Boss 302 race cars were done. On the back I trimmed the underside lip to where the spot welds were. Again from the 10 o'clock to 2 o'clock position. I would not trim the back fender lips past the spot welds since these give a lot of strength to that area. You will find the process of 'rolling the lips' on the back fender will be more of a challenge because there are two thicknesses of metal unlike the fronts that are a single thickness.
