1 - 20 of 33 Posts
· Registered
Hi folks, there is some rust inside my water channels above my door and windows. What do you think about this? Does it seep through into the headliner? I don’t see any leaks from there. And how easy/hard is this to be fixed?
Automotive lighting Wheel Hood Motor vehicle Tire
Automotive lighting Hood Motor vehicle Wood Automotive exterior
Vehicle Automotive tail & brake light Automotive lighting Hood Car
Automotive lighting Motor vehicle Vehicle door Fender Automotive exterior
Automotive lighting Hood Motor vehicle Automotive exterior Vehicle door
Automotive parking light Automotive lighting Hood Motor vehicle Automotive tire
· Registered
Ok I figured. Good thing I don’t even have a 401k!- what would this even be? A roof skin? Or like patch panels? How would you even repair the panels with overlapping metal?
First step is removal of all the old seam sealer and stripping paint to find out the extent of the rust. Then, cut out the "bad" and weld in the patches. Chances are the rust extends way beyond what you can actually see. :-(
· Registered
Discussion Starter · #7 ·
Do the chrome rails on the drip rail come off? I didn’t see any clips. I am scarred that it’s real bad under everything from being unprotected for so long.
· Registered
Yes. I use a "church key" (bottle opener) with the end covered in PVC tape so as not to scratch them. Typically, you won't find rust underneath them though.
· Registered
If you don’t want to go full in right now. You could try scraping the broken paint with pick, treat with Metal Prep and touch up with POR15 with a small paint brush. Then paint over with some red automotive paint for UV protection. That might hold it off until you’re ready to dig in, if ever.
· Registered
Discussion Starter · #13 ·
Good idea since I won’t dig into it now. Maybe I’ll look it into it. So what kind of pick? And metal prep-just like primer or?
· Registered
Discussion Starter · #14 · (Edited)
I’m gonna attempt to find video on a drip rail removal. Just incase I want to for easy access.
for clarification, you pry from where the yellow arrow is and push up?
Wood Automotive exterior Tints and shades Font Publication
· Registered
Not sure. Tomorrow I will look into it when it’s day light. I was thinking about removing the drip rails, and painting the top of the part where water sits since the paint is so cracked.
What has cracked is the seam sealer underneath, allowing water to get between it and the metal. The rust swelled the area and caused more cracking. The sealer should all be removed before attempting to treat any rust.
1 - 20 of 33 Posts
