Rust
751 3
I have a couple little (smaller than a dime) rust spots. I am not ready to repaint yet, what should I do?
It's white and I my first thought is to clean them up and use white primer, so it won't look so bad.
I don't want it to get worse, and living in Seattle the moisture doesn't help.
Thanks for your help,
Burke
'65 Coupe 289 V2 AT PB
if your willing to live with primer showing.... then lightly scuff sand your spots... get some rust-kill spray... can get it about anywhere . spray it and get some white spray paint and spot paint the area's.. not a good Idea to leave primer exposed...primer draws moisture...will just make matters worse.... plus paint might be less noticiable than primer ....for now. ( in Wenatchee)
Ken
Definitely topcoat any primer. Or use epoxy primer, which does not absorb as much moisture IIRC - Dickson
1965 GT fastback
There's a fine line between "hobby" and "mental illness" - Dave Barry
