1 - 20 of 145 Posts
So I really appreciate all the information on this site, and I hope my car can help someone going through similar stuff.
All that being said; while I've worked on cars professionally all my life, this old car stuff can frustrate the best of techs.
I hope my less than spectacular project and progress are a help or at least entertainment to others in the classic Mustang world.
Enjoy the chaos!!
The day I bought it.....
So when I bought it, I knew it had a bad clutch cable. I patched it and managed to drive the car a few miles before needing to have it towed. the previous pic was taken waiting for the wrecker. A 150$ cable and 2 mile test drive later, I figured out the long tube headers were overheating the nylon inner jacket of the Modern Driveline T-5 cable. Game on!! A ton of research and another 150$ later.... I ended up with log manifolds and Magnaflow 2.5" adapters. Problem solved! Only a few thousand more to go!
17x8 Thanks for looking., 2nd66, I love your build thread and used it for tire selection
AFTER I bought it (read: LEARN FROM MY MISTAKE!) I noticed the front tires just didn't seem to sit right. The left rubbed and the right was way under the fender. So I found this... If you can't see the bend , the right frame rail is bent
So luckily since I saved these pics, 3 months worth of work can be shown. Unplanned above all the other work needed. Excuse the messy garage and shoddy welds!!
Discussion Starter #8 (Edited)
Oh and let's not forget the surprise cracked floor support on the other side...It's all in but can't find pics of all million plug welds
Discussion Starter #9
Here it is after reassembly and new front tires. The P.O had way small tires on the front because they rubbed I guess. The new ones are 225 45 17 which will go all 4 corners eventually so they can be rotated. Car rolls straight and no rubs now. My thanks for the frame pics I found on this forum. Now I can get started!!
Welcome to the board,...what are the Build plans?
Discussion Starter #11
Thanks, supermod! I will post pics of more stuff soon. I have acquired an 88 5.0 GT complete for a full EFI resto mod complete with A/C and rolling restoration to a period correct color. I plan to drive the car with limited down time as I check projects off the list. My guestimate is at least 2 more years. (picture is a dream simulation!!)
Discussion Starter #13
Pics of '88 donor car. Although ugly and weather-worn, this car is all factory 2 owner believe it or not.
Discussion Starter #14 (Edited)
The '88 "combover" is finally out...
Discussion Starter #15
Engine pics
I know it is slow and uninteresting. But I know if someone is polite enough to look at my work in progress, I should at least post pics! Engine and trans are separated and engine is partially stripped. I am glad to report that every bolt came out as if the engine was new (despite it's appearance). Factory clutch looked like it would have worked had I just dropped it in. This engine is truly as perfect as they get so far. The gasket and seal kit is ordered, and the journey continues...
Nice work! Are you planning on keeping the serpentine setup? I did and love it. There’s a good routing method for the belt that keeps the AC compressor but deletes the smog pump and power steering. There are lots of ways to handle it, but that’s what I did.
Discussion Starter #17
Absolutely on factory serpentine, Blake! You wouldn't believe the trouble I've had with matching vbelt pulleys. I found this on some 5.0 site I think:
Discussion Starter #19
No doubt. The current 302 runs well, except for valve train woes due to the self guiding rockers on these '76 heads. I weighed the options of a teardown with machine work/new heads and decided to go the smooth power way with the roller motor.I just lucked up on finding a virtually untouched FI motor donor car. I owned an unmolested (except by my foot!) '92 5.0 LX for years until I lost it to progression of life (READ: kids...) That car was so much fun and trouble free, it was a no-brainer to go that way with this car since it was rather hacked up and not a rare or highly optioned car.
Discussion Starter #20
Little steps keep us motivated!
I was able to do a little work while on break at work. Eliminated the power steering section of the A/C bracket. I think it looks much cleaner and less intrusive! I also cut the smog pump hangers from the alternator/auto-tensioner bracket, but I'm trying to make it pretty before I post pics.After and before shown respectively.
1 - 20 of 145 Posts
