1 - 20 of 95 Posts
I posted a few months back to introduce myself and this project. Thought I would try to share my misadventures on here as this project creeps along. I don't post much, but I am getting pretty good at using the search feature to get my Mustang rebuild questions answered. Every question that i've needed an answer to seems to have already been asked/answered on this site. Feel free to ask any questions or give any advice. I'm going real slow on the project trying to do it right.
This was a lower optioned 67 coupe, but it was a factory S-Code. Manual steering, manual drum brakes, 3-speed, no console, no A/C, but it did have a luggage rack!
It's been about a year since we pulled it out of the pasture and started removing rust. I'll add more pics as I get a chance. Thanks for looking!
2017-11-10_02-52-28 by M L, on Flickr
2017-11-10_02-41-10 by M L, on Flickr
2017-11-10_02-34-15 by M L, on Flickr
Welcome to the board,...any more pictures?
As pictured, that looks pretty much like the way and shape that I saw / bought mine.
That’s a very trusting dog you’ve got. I almost missed him.
Discussion Starter · #3 · (Edited)
Hope to install the front aprons and radiator support/crossmember this week. Then will start on patching the defrost vents under the cowl. Both were rusted out which allowed water to get to both floor pans. Also working on installing the Kelsey/Hayes calipers and other assorted front end pieces as I collect them.
2017-11-11_01-30-59 by M L, on Flickr
20170122_192026 by M L, on Flickr
Discussion Starter · #6 ·
Dumped Photobucket, went back with Flickr.... Hope this works. Will try to get some up to date pics today.
Reactions: Israel
Discussion Starter · #7 ·
Reactions: 7T02S and image98
Discussion Starter · #9 ·
We're just south of Fort Worth near Cleburne.
That's Molly the Shop Dog. If i'm in the shop, she's in the shop. Doesn't matter how much noise I make.
Discussion Starter · #10 ·
Core support showed up yesterday, but it looked like it had been used as a wheel chock sometime during transport. Replacement is on it's way. Spent today blasting and painting random parts and cutting out more rusted floor sections to get ready for the pans.
20171111_122129_zpsydkhucnu by M L, on Flickr
Discussion Starter · #12 ·
Replacement radiator support arrived while I was at work yesterday, when I got home this morning I got it mocked up and clamped. Next step is to use the search feature and see if I can find any of those old threads that give all the correct measurements. Can't wait to start welding but I want the placement to be spot on before I create a mess I can't fix.
2017-11-17_04-56-41 by M L, on Flickr
20171117_154936 by M L, on Flickr
1967 Mustang Hardtop
A low optioned '67 that's an S code? Jeez. What is this? The 80s? Where's the beef, man?
Discussion Starter · #14 ·
Measured, cross measured, leveled, checked height, checked width, cross measured again, clamped, put old fenders on, checked again, then tacked the front core support. OCD will make me do it again before final welding.
Found one issue with the the driver's side shock tower being about 1/8" - 1/4" lower than the passengers side. Everything else around it is square and level. After closer inspection it looks like it was that way from the factory. It appears that it was just installed a little lower than the other. No obvious damage or replaced parts. I'm guessing that was just acceptable frame tolerance in 1967 Ford factories.
Also, began disassembly of the 390 and prep and painting of steering linkage.
20171016_204716 by M L, on Flickr
20171017_191152 by M L, on Flickr
Reactions: 120mm and rpm
Discussion Starter · #15 ·
Slow progress, slower updates...
Got the core support welded on today after checking again that the engine bay was square. Spot/Rosette welds are getting better and easier to blend. Test fit the driver's side floor pan. It looks like it will be a good fit.
Also dropped the block off at the machine shop for a bath, check-up and hone. Hope it gets a clean bill of health.
20171127_181724 by M L, on Flickr
20171206_181401 by M L, on Flickr
20171127_181650 by M L, on Flickr
Reactions: Caper50
Discussion Starter · #16 ·
I've always wondered why this car had a 390 option but nothing else. Not sure if it was custom ordered this way as a hotrod, if so I would think that the 4 speed would have been added on to the list. Who knows.
Is that literally the only option? Besides an AM radio I bet.
I would think either someone just had enough dough for one expensive option or it was a dealership car to show off the new 390 powered Mustang. A Marti Report MIGHT be able to shed a little light on how it was ordered. Maybe.
Reactions: Turnall
Discussion Starter · #18 ·
Marti report will be coming soon. Not sure about the radio, had a junky aftermarket one when we got it. It did have a luggage rack on the deck lid and "Remote" controlled mirrors. I think that may have been an option that year. :shrug:
Too bad rust proofing wasn't an option.
1 - 20 of 95 Posts
