What do you use for sand blasting? I got a small sand blaster and played with it. I use play sand it worked ok but not great. I think there must be some thing better to use. it does get rid of the rust though.
We just discussed this topic
black beauty (coal slag) is probably the best price to performance blasting product.
I posted the same question about 2 days ago. I have 400 grit aluminum oxide in mine. It works excellent. It is fine enough to get into all the cracks and crevices. It will leave a very fine surface finish and it will get everything off the surface.
I use the stuff from menards it might be coal i dont know. It is called black magnum.
I love your post.Got my dream car.How am I going to fix this.(With the pic of 67).I just roll in the floor when I see it.I promise you that YOU are not alone!You have to take your time.Take lots of pics & Tag & Bag every nut & bolt.I started with gutting the interior.Now I'm working on getting all of it lined out.Pulled seat covers off & blasted seat tracks & frames while covers where on the way.Paint seat backs while friend cover seats.2 front seats done.Ordered Carpet & headliner-Done.Cleaned door panels & put on new trim-done.Back seat clean up only.....done.When I send it out for body & paint - I'm going to rebuild the engine & send tranny out for rebuild.When the car comes back The Int.will be ready & so will the drive train.Break it down into small projects & finish ea.1.You'll just have a zillion projects!!!!O yeah, my blaster has medium glass beads.Works great.......
Good Luck
JRW
I'm getting near the end of sandblasting and I use play sand exclusively. The large body panels were hand sanded (electric DA) or media blasted. The sandblaster works great, but it is a low pressure system (I plug it into the 115VAC outlet) so the metal doesn't heat/warp and blasting takes a long time.
Nearly everyone who started balsting at the same time as I are weel into priming or painting by now! However, the finished product is just fine.
Use a good quality epoxy primer as the first coat of primer. I use PPG's DP90.
I use #5 grade sandblasting sand. It's about the consistency of table salt. It leaves a nice smooth finish (almost like bead blasting) and doesn't tend to clog like play sand does. I get it at a sandblasting supply shop.
